cosx
6 years agoData arrival Path in timing analyser
Hi everyone,
I just came across a very confusing thing about data arrival path in timing analyser. This path mismatched the actual routing path in the chip planner.
I placed a 20-bit adder betwee...
KhaiChein_Y_Intel
6 years agoHi Mingqiang,
Can you try to simulate the design and see if the signals give expected result?
KhaiY
cosx
6 years agoHi KhaiY,
Continuing from the gate-level simulation using Modelsim.
All ouptuts of the adders are correct as expected.
However, I still doubt whether gate-level simulation gives us correct functions in the real chip, though it is reliable to some extent.
I would use oscilloscope to do actual tests to find out what exactly has happened!
Thank you!
Mingqiang
