cosx
6 years agoData arrival Path in timing analyser
Hi everyone,
I just came across a very confusing thing about data arrival path in timing analyser. This path mismatched the actual routing path in the chip planner.
I placed a 20-bit adder betwee...
KhaiChein_Y_Intel
6 years agoHi Mingqiang,
Can you try to simulate the design and see if the signals give expected result?
KhaiY
cosx
6 years agoHi KhaiY,
Thank you for your method.
I guess the simulation you refer to is the gate-level simulation.
I had done RTL-level one before and the output sof the adder were correct.
I tried gate level simulation, but it did not give me any timing information about the cascaded length delay. I thus abandoned it.
I would double check the functionality simulation at this level latter. Nevertheless, since I will get an oscilloscope today, it is worth measuring the outputs to see the exact waveforms.
Thank you still for your concern! I will update what I found with you!
Best Wishes,
Mingqiang
