16 years agodata adresses on physical mem
hello,
can someone help me, I want to know if there's a way to print the adresses of my data on the physical memory. I want to know if there are some ALT functions allowing this kind of manipilation and which I can put in my C code. I'm using nios 2 fast proc. thks for your attention;3 Replies
thx , for your help
--- Quote Start --- If you mean to print the address of a variable --- Quote End --- In systems with MMU the address in CPU memory and physical memory can be different. Variable may exist in CPU memory but do not exist in real memory. - Altera_Forum
If you mean to print the address of a variable you could do something like this:
int i = 3; printf("The location of variable 'i' is %d.", &i); The '&' gives the address of an object instead of the data itself. Normally I print my addresses in hex so this might work better: printf("The location of variable 'i' is 0x%x.", (unsigned long)&i);
