14 years agoDAC/ADC not at full range.
I am using the THDB_ADA daughter card and the DE2-115. I am feeding an NCO output (2Vpp sine wave) from the DAC straight into the ADC through an SMA cable. However, the values registered by the ADC o...
14 years ago --- Quote Start --- I am using the THDB_ADA daughter card and the DE2-115. I am feeding an NCO output (2Vpp sine wave) from the DAC straight into the ADC through an SMA cable. However, the values registered by the ADC only indicate an input value of ~730mV peak to peak, when it should be at full range. Any ideas on what's going on? --- Quote End --- Do you used the Cyclone III with the Daugtercard HSMC? :rolleyes:
