14 years agoDAC/ADC not at full range.
I am using the THDB_ADA daughter card and the DE2-115. I am feeding an NCO output (2Vpp sine wave) from the DAC straight into the ADC through an SMA cable. However, the values registered by the ADC o...
14 years agoIs the output frequency above the transformer cut-off frequency? Did you measure 2 Vpp with 50 ohm load or open circuit? The AD input has 50 ohm impedance, thus it's halving the magnitude.
