12 years agoCycloneV's Altera PLL V13.1 simulation problem
Hi, I'm using Altera SOCkit (CycloneV) and generated altera pll v13.1 using quartus v13.1.0.162 web edition + latest patch. Now I'm trying to simulate the generated pll using modelsim but ...
12 years agoHi,
I finally understood that only vhdl file created by quartus is not enough. I needed to include one more module hiden inside a folder (PLL_0002) into a project as well. By doing this, warnings seems to be disappear but now I'm facing a new problem. It's appear that modelsim (free version) can only simulate one hdl language at a time, which my code is in vhdl while PLL_0002 module is in verilog. !!! Can anyone confirm that it is true or not ? You guys have no problem with mixed-language simulation means you are coding in verilog or using licensed version, haven't you ? Below is my latest warning message. --------------------------------------------------------------------------------------------------------- # ALTERA version supports only a single HDL # ** Error: (vsim-3039) E:/xxx/xxx/xxx/project/cyclone_5_pll_sim/vhdl/top.vhd(38): Instantiation of 'PLL_0002' failed. ---------------------------------------------------------------------------------------------------------
