12 years agoCycloneV's Altera PLL V13.1 simulation problem
Hi, I'm using Altera SOCkit (CycloneV) and generated altera pll v13.1 using quartus v13.1.0.162 web edition + latest patch. Now I'm trying to simulate the generated pll using modelsim but ...
12 years agoHi a_x_h_75 and FvM,
Have tried both of your comment but still not work. I suspected that there's may something wrong about my sim library. Below are warning displayed from my modelsim. Have you ever seen warning like this before ? --------------------------------------------------------------------------------------------------------- # Loading cyclone5_pll.testbench(behavioral) # Loading cyclone5_pll.top(behavioral) # Loading cyclone5_pll.pll(rtl) # ** Warning: (vsim-3473) Component instance "pll_inst : PLL_0002" is not bound. # Time: 0 ps Iteration: 0 Instance: /testbench/MODULE_TOP/PLL_MODULE File: E:/xxx/xxx/xxx/project/cyclone_5_pll_sim/ipmodule/PLL.vhd # ** Warning: (vsim-8684) No drivers exist on out port /testbench/MODULE_TOP/PLL_MODULE/outclk_0, and its initial value is not used. # # Therefore, simulation behavior may occur that is not in compliance with # # the VHDL standard as the initial values come from the base signal /testbench/MODULE_TOP/wCLKOUT. # # ** Warning: (vsim-8684) No drivers exist on out port /testbench/MODULE_TOP/PLL_MODULE/locked, and its initial value is not used. # # Therefore, simulation behavior may occur that is not in compliance with # # the VHDL standard as the initial values come from the base signal /testbench/MODULE_TOP/wLOCK. # ---------------------------------------------------------------------------------------------------------
