[CycloneV SX] LVDS IO datarate
- 10 months ago
I'm not completely sure about your design parameters, but AD9783 interface with 500 MHz DAC clock is actually using 2x500 MSPS LVDS Data rate, because the data stream involves I and Q data.
Cyclone V isn't able to handle LVDS with 500 MHz DDR clock and 1000 MSPS.
Regards Frank
Yes, it is correct, Cyclone V SX can't reliably sustain 500 MHz DDR LVDS using DDIO registers. Furthermore, the 640Mbps figure in the documentation applies to dedicated LVDS SERDES channels. However, even using the dedicated LVDS SERDES blocks, Cyclone V maximum at 840Mbps/channel, is still below the AD9783 effective 1000MSPS.
So, using bus widening (SERDES factor 4) to lower the internal clock rate while maintaining throughput is the suggested alternative, and it requires devices that support SERDES factor up to x8 and more than 1Gbps/channel. I confirmed from the datasheet of Cyclone 10 GX, Arria 10 GX, and Agilex 3/5, they can meet the requirements.
Aqid
