AGofs
7 years agoCycloneV :MSEL(4:0) and VCCPGM voltage
Good morning , I'm working with CycloneV GX at AS (x1 and x4) Standard configuration. I've read at CycloneV Handbook ,that MSEL(4:0) pins shall be connected to VCCPGM or GND directly. The Voltage ...
AGofs
7 years agoThank you ,JwChin for answer about "CycloneV :MSEL(4:0) and VCCPGM voltage" issue!
The issue is clear.
Does your last answer "The RS and RP external resistors is to give an effective 100 ohm differential output impedance" is connected to this issue or to another?
JonWay_altera
7 years agoSorry, it is to another thread! :)
