12 years agoCycloneIV Reconfiguration from network without rewriting flash
Hi, as a hobby/learning project, I'm building a system with two major uses: 1. it should control LED lighting in my home (6000 WS2812) 2. it should help the rendering farm when I'm not a...
12 years agoHi Simon,
Are you in the process of designing a custom board? If so, then all you need is an intelligent configuration controller, eg., a microcontroller with external memory for configuration data storage. That storage can be non-volatile (SD card), or volatile (SDRAM) depending on the capabilities of your microcontroller. The FPGA can then be configured by the microcontroller using passive serial or fast passive parallel. I doubt Cyclone IV will support OpenCL, so you'll want to leave that "thought" for another project. Cheers, Dave
