16 years agoCycloneIII: LVDS_E_3R TX output voltage
I am currently using an EP3C10F256C8 Cyclone III in a project for LVDS transmission/mixing. It contains a 2x5-channel input on I/Obanks 5 + 6 (true LVDS input: I/O standard LVDS) and a same-sized output on I/Obanks 3 + 4 (emulated LVDS output: I/O standard LVDS_E_3R). The used LVDS input/output frequencies range from 60 to 75 MHz, the whole system runs fine from a functional point of view. However, I am measuring a higher LVDS TX voltage on the LVDS_E_3R outputs, though following the Device Handbooks recommendations with a VCCIO = 2.5V and a 2x120 + 170 Ohms resistor network plus a differential load of 100 Ohms each. My measurements: VOS (dc offset) = 1.25 V, VOH = ca. 1.7 V, VOL = ca. 850mV. So I end up with a VOD (diff. amplitude) of ca. 850mV, higher than the ANSI standard allows. I have tried to change pre-emphasis and slow slew rate assignments, but with no luck/effect. A fix would be to re-calculate the 3R network. But I was wondering why the recommended settings end in these values or if I have overlooked anything related. Thanks for any hint, EP3Seb.1 Reply
A simple hand calculation of the voltage divider clarifies, that the differential voltage can't be 850 mV. I also don't remember to have seen a too large output with E_3R. So something must be expected wrong, either with your hardware setup or the measurement.
