17 years agoCycloneiii Flip Flop mistery
Hello! I have a cycloneiii starterkit board from altera and terasic. This little one has a RS232 interface in the PIN_E18 and PIN_H17 , RXD and TXD respectively. I test the pins by making a loo...
17 years ago --- Quote Start --- Hello! architecture loopback_registered of uart is beginlb_reg: process (clk,rst)beginif rst='1' thenTx <= '1'; -- then --- Line always at one!elseif rising_edge(clk) thenTx <= Rx; -- Lets sample incoming Rxd!end if; end if; [/INDENT]end process; [/INDENT]end loopback_registered; --- Quote End --- I changed some syntax errors in the quote above (highlighted in red). Possible causes why this does not work: 1) did you update the pin assignments for your clk and rst signals? Make sure that you do not have unconnected pins? 2) did you check that you did not use an "inverted" rst signal (e.g. from an active high KEY on your board)?
