17 years agoCycloneII-JTAG Mode
Hi, I'm using CycloneII(EP2C8Q208). my problem is can't configure jtag mode. so i checked pin number. but i couldn't found error. and i checked power supply but that's working. i using usb_b...
17 years agoYou haven't mentioned what error is shown by QUARTUSII.
Have you tried the following? 1. Assignments>Device>Device and Pin options> Configuration select configuration scheme as active serial 2. Assignments>Device>Device and Pin options> unused pins as input tri-stated 3. In the programmer select mode as JTAG 4. And the file to select is .sof and not .pof
