17 years agocyclone3 pll
hi while implementing the pll using mega function , it generated code with ENTITY pll IS PORT ( inclk0 : IN STD_LOGIC := '0'; c0 : OUT STD_LOGIC ...
17 years agoHello eveybody!
I'm simulating a pll but an error always appears: Modifying C:\Applications\Modelsim6.1c\win32/../modelsim.ini# Error: Acces denied.# Unable to replace existing ini file (C:\Applications\Modelsim6.1c\win32/../modelsim.ini). File can not be renamed.# ** Error: (vcom-19) Failed to access library 'cycloneiii' at "cycloneiii". Thank you very much for any help! information : I am not in administrator session and I cannot modify anything I didn't create.hands
6 years agoyou have no add the cyclone iii library.you need to add it so you can use it.
