15 years agocyclone3 nstatus pin keeps dropping low
Hi, all. My EP3C40Q240C8N can't work, and I found its nstatus pin would drop to low intermittently after board powered. there is no blaster down-loader, and nconfig pin keeps high. (waveform is...
15 years agoHi, FvM, thanks a lot for your patient help.
I enlarge the config_done pin's serial resistor, which connect to a NPN with indicating light. The device work well then. I don't know why, but it's OK now. Thank you very much.
