15 years agocyclone3 nstatus pin keeps dropping low
Hi, all. My EP3C40Q240C8N can't work, and I found its nstatus pin would drop to low intermittently after board powered. there is no blaster down-loader, and nconfig pin keeps high. (waveform is...
15 years agoHi, FvM, thank you very much for your reply when I'm worrying about this all day.
You mean this is normal? Actually, this is my second version board. The previous one works well, and nstatus pin always high when power on but not configure it yet. (this is the only difference between twos). By handbook, the only reason could cause nstatus drops low seems to be low nconfig or monitored power. because there is no blaster installed yet, of course no configuration start yet. so nconfig pin is checked high. For this reason I guess there is some problem in power supply. However, power is alright too. (1.2v, 2.5v, 3.3v) Power condition is checked with scope, and every related pin is alright. I tried to replace the power filter capacitors (from about 50uf to 200 uf), but no help. My configuration are jtag and AS. I compare my schematic to handbook, but no difference found. The serial configuration device is EPCS16 and EEPROM DS28E01P-100. Specification is shown in attachment. Actually, I don't think there is any problem with schematic, because previous board works well. But the board made after that all have the problem I mentioned. I want to find out the reason. Thank you very much.
