16 years agoCyclone3 fails to configure
Hi, I have custom board with EP3C55F484. I'm trying to configure Cyclone using .jic file in QuartusII 9.0. The problem is that after Quartus programmer says that "operation was success...
16 years agoIf the EPCS verification failes, you can't expect that the FPGA can be configured correctly with the EPCS data.
I see a least these possible explanations: - the EPCS is defective (unlikely) - you managed somehow to protect a sector of the EPCS device (would be possible with the NIOS flash programmer or when you're operating a serial flash controller in your design) - the EPCS programming fails due to signal quality issues of the JTAG chain. This may be also caused by crosstalk of other signals (e.g. a clock) to the JTAG signals, particularly TCK.
