17 years agocyclone2, odd problems
(currently working with altera on these problems, just curious if anyone else has seen them) # 1 processor connected to cyclone2, jtag fails with processor running. (have to hold the reset but...
16 years ago --- Quote Start --- JTAG is one of those things that seems simple because it's such a low data rate --- Quote End --- You hit the point. Although the data rate is low, the FPGA internal logic processing TCK isn't. So you can achieve false JTAG clocking either by ringing edges or crosstalk from other on-board fast signals. The latter should be considered if configuration in a multiple devices chain fails, after ather parts of the design started operation.
