YYang79
5 years agoCyclone10GX Temperature Issue
I use a cyclone 10 gx fpga (10CX150YF780C5G) on my pcie card. One transceiver is used as a 10Gbps fiber link and other 4 transceivers are used as Gen1 Pcie X4 lanes. No external memory interfa...
SengKok_L_Intel
5 years agoHi,
If enable the serial loopback can see the problem, you should be able to test on other channels as well since it does not use the PHY channel (fiber cable), you can just change the Pin assignment will do.
Do you have a signal tap that can show the pass and fail condition?
Regards -SK
YYang79
5 years agoYes I have.
See attached. It shows the data communication at xgmii interface.
