8 years agoCyclone V won't configure via active serial
I have a Cyclone V design (5CSEBA5) that I am trying to configure using a EPCQ128 device
I have created a .sof file that I can load into the FPGA directly (Jtag USB Blaster) and it works fine (blinks my user debug LED) I have tried to take that same .sof file and create the file to program the EPCQ128, but I am not sure I am going about this the right way. I used the "Convert programming file" program with the following settings Programming File Type = Jtag Indirect Configuration file Configuration device = EPCQ128 Mode = Active Serial x 4 File name = output_fille.jic create memory file and create config data boxes are NOT checked under "input files to convert" there are: Flash Loader 5CEBA5 SOF Data romulus.sof The romulus.sof file is the same one that I can load directly and get my blinking LED I generate the file, then use the stand alone programmer. I autodetect the FPGA, then "attach" the EPCQ128 In the box for assigning the files I select the EPCQ128 and "change" the file (I discovered that you MUST change the file, not "add"!) to point to the jic file just created. I check the box for programming the EPCQ128 and click start. The FPGA programs with the "factory default SLF" image and the it erases and programs the EPCQ128. I can verify the EPQC128, so everything looks okay. But then I power cycle and expect the FPGA to configure from the flash device, but it fails. I have the MSEL[4:0] pins set to 10011 (standard active serial). I have also tried 10010, for FAST AS. I can probe the pins on the EPCQ128 and I see: DCLK is going at about 80 MHz. nCSO is mostly low, with a short pulse high every 175ms The four data pins are toggling The nCE pin to the FPGA is tied low NCONFIG and NSTATUS are pulled high (10K) - (addition: Nstatus does get asserted low every 175 ms) Config_done drives a FET which in turn drives an LED. This circuit works as expected when I program the FPGA directly via JTAG I figure that the basic JTAG connection to the FPGA is okay as I can configure it directly and it appears I can program the FLASH device through it. The connections between the FPGA and serial FLASH device appears to be proper because I can program and verify the FLASH I am suspecting that I didn't create the .jic file properly but I don't know what to do different. I am using a .jic file because that is the only format that the programmer will allow me to select for the file that will get programmed into the attached flash device. I would really appreciate any help here! Rod12 Replies
I'm having the same problem, did you resolve this?
--- Quote Start --- I'm having the same problem, did you resolve this? --- Quote End --- Yes. It turned out to be a circuit problem: I didn't have a pull-up on the config_done signal. Once I added the pull up everything worked properly.
