8 years agoCyclone V won't configure via active serial
I have a Cyclone V design (5CSEBA5) that I am trying to configure using a EPCQ128 device I have created a .sof file that I can load into the FPGA directly (Jtag USB Blaster) and it works fine (...
8 years ago --- Quote Start --- I'm having the same problem, did you resolve this? --- Quote End --- Yes. It turned out to be a circuit problem: I didn't have a pull-up on the config_done signal. Once I added the pull up everything worked properly.
