8 years agoCyclone V won't configure via active serial
I have a Cyclone V design (5CSEBA5) that I am trying to configure using a EPCQ128 device I have created a .sof file that I can load into the FPGA directly (Jtag USB Blaster) and it works fine (...
8 years ago --- Quote Start --- 1.Can you try by selecting Memory Map File check box (which is checked by default Don't Change). --- Quote End --- As I mentioned above, I did click the box to get the map. See the text in blue from my previous post. Would checking this box have any effect other than creating the map file? I have NOT tried programming the FLASH since I created the map file. --- Quote Start --- In .JIC file we already have/integrated serial flash loader so that it can communicate to flash. In .pof file we don't have serial flash loader, So we need to create serial flash loader and load(.sof) first. and then program .pof. --- Quote End --- I will give that a try. Unfortunately, I am about an hour away from where the prototype system is so I can't just go run into a lab and test it quickly. I will drive over there later this afternoon and try this out. Rod
