8 years agoCyclone V won't configure via active serial
I have a Cyclone V design (5CSEBA5) that I am trying to configure using a EPCQ128 device I have created a .sof file that I can load into the FPGA directly (Jtag USB Blaster) and it works fine (...
8 years agoHi Rod, 1.Can you try by selecting Memory Map File check box (which is checked by default Don't Change). In .JIC file we already have/integrated serial flash loader so that it can communicate to flash. In .pof file we don't have serial flash loader, So we need to create serial flash loader and load(.sof) first. and then program .pof. Refer below link for the flash programming https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an370.pdf Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
