8 years agoCyclone V won't configure via active serial
I have a Cyclone V design (5CSEBA5) that I am trying to configure using a EPCQ128 device I have created a .sof file that I can load into the FPGA directly (Jtag USB Blaster) and it works fine (...
8 years agoIf you can configure your device via JTAG then there is no problem with any of the device's configuration pins - nCONFIG, nSTATUS, nCE, CONF_DONE, INIT_DONE. So, you can ignore these.
I suspect, like you, you're creating your .jic file incorrectly. Refer to "how do i create a jtag indirect configuration file (.jic) file with my nios ii hardware and software image? (https://www.altera.com/support/support-resources/knowledge-base/solutions/rd10132010_126.html)". You can ignore steps 1 to 3 and 11, they're required if you want to boot your Nios software from EPCS too. Start at line 4. Ignore the references to map & hex files in step 12. You should then be able to select your .jic file from within the Quartus programmer and configure your device. Cheers, Alex
