8 years agoCyclone V won't configure via active serial
I have a Cyclone V design (5CSEBA5) that I am trying to configure using a EPCQ128 device I have created a .sof file that I can load into the FPGA directly (Jtag USB Blaster) and it works fine (...
8 years agoHi Rod, Try with below options Tick memory file check box while generating .jic file.(To generate output_file.map) The .map file contains starting and ending addresses for boot code, configuration page data, and application code. Or 1.Check the pin nConfig and nStatus in reset state it should be high state. 2.Is it development board/custom board?
- If it is custom board: Do you have any hardware/IC in path on nSTATUS and CONF_DONE (like line driver / TRX).
