12 years agoCyclone V Transceiver Reconfiguration Settings Available When Streaming mif Files
I am using a Cyclone V with the Native PHY IP transceiver. I need to be able to set a bunch of different transceiver settings to different values during runtime for a design I'm doing. Accordin...
12 years agoFrom memory I think you are limited to what you can reconfigure through a streaming MIF as my C5 transceiver design uses both Avalon MM register writes for loopback modes and a streaming MIF for speed changes i.e. Tx local divider and Rx reference dividers.
