11 years agoCyclone V speed is much slower
Hello. I am new to Cyclone V. I took my design for Cyclone III and recompiled it with Quartus II web 13.1. From the timing analyzer, I can see that the maximum clock rate is only 84 Mhz while I was...
11 years agoHere is the summary from the timing report
+-------------------------------------------------------------------------+ ; TimeQuest Timing Analyzer Summary ; +--------------------+----------------------------------------------------+ ; Quartus II Version ; Version 13.1.0 Build 162 10/23/2013 SJ Web Edition ; ; Revision Name ; F ; ; Device Family ; Cyclone III ; ; Device Name ; EP3C40Q240C8 ; ; Timing Models ; Final ; ; Delay Model ; Combined ; ; Rise/Fall Delays ; Enabled ; +--------------------+----------------------------------------------------+ The max speed is 127.98 Mhz +-----------------------------------------------------------------------------------------+ ; Slow 1200mV 85C Model Fmax Summary ; +------------+-----------------+---------------------------------------------------+------+ ; Fmax ; Restricted Fmax ; Clock Name ; Note ; +------------+-----------------+---------------------------------------------------+------+ ; 127.98 MHz ; 127.98 MHz ; myclk|altpll_component|auto_generated|pll1|clk[0] ; ; ; 167.22 MHz ; 167.22 MHz ; PLL1IN ; ; +------------+-----------------+---------------------------------------------------+------+ With the exact same design recompiled for Cyclone V ; TimeQuest Timing Analyzer Summary ; +--------------------+----------------------------------------------------+ ; Quartus II Version ; Version 13.1.0 Build 162 10/23/2013 SJ Web Edition ; ; Revision Name ; F ; ; Device Family ; Cyclone V ; ; Device Name ; 5CEBA4F23C8 ; ; Timing Models ; Final ; ; Delay Model ; Combined ; ; Rise/Fall Delays ; Enabled ; +--------------------+----------------------------------------------------+ The speed is 84.47 Mhz using Quartus ii 13.1 +---------------------------------------------------------------------------------------------------------------+ ; Slow 1100mV 85C Model Fmax Summary ; +------------+-----------------+-------------------------------------------------------------------------+------+ ; Fmax ; Restricted Fmax ; Clock Name ; Note ; +------------+-----------------+-------------------------------------------------------------------------+------+ ; 84.47 MHz ; 84.47 MHz ; myclk|mypll_inst|altera_pll_i|general[0].gpll~PLL_OUTPUT_COUNTER|divclk ; ; ; 218.72 MHz ; 218.72 MHz ; PLL1IN ; ; +------------+-----------------+-------------------------------------------------------------------------+------+
