JWies1
7 years agoCyclone V SoC: When routing HPS CAN0 or CAN1 pins to FPGA receive direction isn't working
I'm using Quartus Prime Lite 16.1. I am programming a Cyclone V Soc on a SocKit / DeNano board. I am accessing the CAN controllers with bare metal code from the second ARM core. With Qsys I select...
FawazJ_Altera
7 years agoHello sir,
So I would check the following items:
1- make sure the CAN is enabled in device tree.
2- Signal tap the routed signals in FPGA. You can send them to me for further investigation.
3- Is there any linux image working?
