11 years agoCyclone V Soc LEDs Issue- Help Required
Hi, I am using cyclone V Soc HPS. Issue I am facing is I have been able to access GPIOs button and DIP switches but i am unable to access LEDs. I am using lauterbach for debugging. Changes made by...
11 years agoActually i was using lauterbach, I got an example targetting GPIOs of altera Cyclone V Soc, when you build this application using ARM-DS5, along with the binary of your target application a uboot binary is generated, and a script is available for loading both of these binaries to target platform. I ported the script for lauterbach and used same uboot binary generated with the example and voila it worked :)
