13 years agoCyclone V SoC HPS2FPGA AXI Master - How to enable?
Has anyone been able to use the HPS2FPGA AXI Bridge to access an avalon-mm slave in the FPGA fabric. The Cyclone V SoC Kit's Golden Hardware Reference Design (GHRD) connects an on-chip ram to the hps...
11 years agoHi
I Would appreciate it if someone can guide me how to read and write to a on chip memory connected to the H2F Bridge (Full) BAREMETAL. I do the following while (1==1) { alt_write_word ((0xc0000000 + TEST_ONCHIP_MEMORY_BASE+loop), ~loop); ReadValue = alt_read_word (0xC0000000 + TEST_ONCHIP_MEMORY_BASE+loop); ReadValue = alt_read_word (0xC0000000 + TESTFIFO_RD_BASE+loop); ReadValue = alt_read_word (0xC0000000 + TESTFIFO_STATUS_BASE+loop); loop++; } The On chip memory, TESTFIFO RD and TESTFIFO Status is all conencted to h2F bridge. I can read successful from on chip memory with offset 0. But when reading from TESTFIFO_RD and TESTFIFO_STATS i read 0xffffffff, the inverted of loop (0x0). So i read the same value for all 3 ports. Also when the while loop re-execute the second time e.g. loop = 1, the software crash when writing to the on chip memory. To initialize the H2F Bridge i use the Altera library in alt_address_space.h & alt_bridge_manager.h as follows status = alt_addr_space_remap(ALT_ADDR_SPACE_MPU_ZERO_AT_BOOTROM, ALT_ADDR_SPACE_NONMPU_ZERO_AT_OCRAM, ALT_ADDR_SPACE_H2F_ACCESSIBLE, ALT_ADDR_SPACE_LWH2F_ACCESSIBLE); } if (status == ALT_E_SUCCESS) { // STEP 12: Attempt to initialize bridge status = alt_bridge_init(bridge, NULL, NULL); // status = alt_bridge_init(ALT_BRIDGE_F2H, NULL, NULL); status = alt_bridge_init(ALT_BRIDGE_H2F, NULL, NULL); // status = alt_bridge_init(ALT_BRIDGE_LWH2F, NULL, NULL); } I have a baremetal program working, preloader / spl, u boot and LW Bridge all is working 100%. Thanks
