9 years agoCyclone V Soc Development kit UART signal on GPIO pins
HI, I am writing serial driver for cyclone V. UART0 is working perfectly when I connect it to PC using the USB connector for serial (J8). But if I try to get output through J9 which are GPIOs for the same UART, I don't receive anything on teraterm but what I send from teraterm is received correctly in the controller. Same thing is happening with UART1. I ensured the TX pin is working fine by connecting the TX and RX pin in loopback and making sure that what is send is correctly received.
So to conclude 1. TX pin is configured correctly 2. Baud rate and other settings are fine but no output is shown on teraterm If anyone can help, I would be very grateful.1 Reply
How it Teraterm connected to J9?
Is it through a standard DB-9 or DB-25 RS-232 connector? It that's the case, the voltage & polarity are not the same: a level conversion chip is needed. Regards
