9 years agoCyclone V Soc Development kit UART signal on GPIO pins
HI, I am writing serial driver for cyclone V. UART0 is working perfectly when I connect it to PC using the USB connector for serial (J8). But if I try to get output through J9 which are GPIOs for the...
9 years agoHow it Teraterm connected to J9?
Is it through a standard DB-9 or DB-25 RS-232 connector? It that's the case, the voltage & polarity are not the same: a level conversion chip is needed. Regards
