13 years agoCyclone V SoC - Shared Memory Controller
Hi @all, I have a problem generating a Design with connection from FPGA to the HPS-Memorycontroller. I set up a QSYS-System with the connections and now try to get data from this Memory. ...
10 years agoI'm trying to get the FPGA to HPS SDRAM interface working but it just freezes on memory access. I have set up a Avalon-MM Read/Write port on a DE0-nano-SoC. I have tried reading or writing to a lot of different addresses but the result remains the same.
* What address are you using? I have done most of the testing with 0x30000000 which should hit the ram regardless of the 0x20000000 offset described in this thread. * Have you seen any examples of this that is compatible with DE0-nano SoC? * Is it enough to build the preloader? I built the preloader from my fpga project but then I imported another U-boot because my preloader would not work with U-boot from the SD image. I also had to replace the kernel, so a lot of the hardware fails to initialize. So far I believe that this should be ok for testing as long as the SDRAM controller gets initialized by the preloader. I can see that the reset bits for the FPGA to SDRAM ports gets set when I use this setup. * Is there any way to catch this error in a more controlled way than freezing? * In case I need to create a bare minimum fpga project to test this, what example should I use as a base? I have a deep understanding of the FPGA part but my linux skills are still at a very basic level.
