13 years agoCyclone V SoC - Shared Memory Controller
Hi @all, I have a problem generating a Design with connection from FPGA to the HPS-Memorycontroller. I set up a QSYS-System with the connections and now try to get data from this Memory. ...
13 years agoThat sounds like the bridge hasn't been opened up. For a master in the HPS (like the CPU) to be able to access anything in the FPGA the following is required:
1 - Bridge needs to be clocked and pulled out of reset 2 - Bridge needs to be enabled in the address map (this is enabled in the GPV of the L3 interconnect) By default the HPS-to-FPGA bridges are not mapped in after the system comes out of reset so software has to do that.
