13 years agoCyclone V SoC - Shared Memory Controller
Hi @all, I have a problem generating a Design with connection from FPGA to the HPS-Memorycontroller. I set up a QSYS-System with the connections and now try to get data from this Memory. ...
13 years agowaitrequest is an output of the memory controller, so i'm not sure the F2H port would be the problem. can you check the status signals of the memory controller to see if it has passed calibration?
