13 years agoCyclone V SoC - Shared Memory Controller
Hi @all, I have a problem generating a Design with connection from FPGA to the HPS-Memorycontroller. I set up a QSYS-System with the connections and now try to get data from this Memory. ...
13 years agoIt seems Voroshazi and I are trying to do a very similar thing. I have also been working on moving data from the HPS to the FPGA SDRAM across the HPS2FPGA bridge. I too have been able to achieve this but have the same issue in that the throughput I am getting is in the order of 58MB/sec (by memcpy from HPS SDRAM to FPGA SDRAM). I'm not using a DMA either and wondered if you had been able to achieve better than this (I need at least 80MB/sec for my application)?
does anybody have any insight as to why the data rate is so low? I was expecting it to be much faster.
