13 years agoCyclone V SoC - Shared Memory Controller
Hi @all, I have a problem generating a Design with connection from FPGA to the HPS-Memorycontroller. I set up a QSYS-System with the connections and now try to get data from this Memory. ...
13 years agoI don't know all the details but there is an issue with the way the preloader sets up the FPGA-to-SDRAM interfaces. So it's a software fix to resolve the issue. The issue only affects the read performance, so if you are seeing write performance issues then it is most likely something else going on.
