13 years agoCyclone V SoC - Shared Memory Controller
Hi @all, I have a problem generating a Design with connection from FPGA to the HPS-Memorycontroller. I set up a QSYS-System with the connections and now try to get data from this Memory. ...
13 years ago --- Quote Start --- Also so that you don't spend time debugging a known issue, there is a known issue with the throughput between the FPGA and the HPS. This issue will be corrected in the next update. --- Quote End --- Can you elaborate more on this? I have some problems with the throughput. Are you referring to an update of Quartus, EDS, or the kernel?
