13 years agoCyclone V SoC - Shared Memory Controller
Hi @all, I have a problem generating a Design with connection from FPGA to the HPS-Memorycontroller. I set up a QSYS-System with the connections and now try to get data from this Memory. ...
13 years agoHi BadOmen, thank you for this hint.
Do you have an overview of issues for the SoC? If you are deep in the "SoC-World" maybe you could answer my question how to build a working preloader and uboot?! My problem for now is that the generated preloader.ds and uboot.ds won't work properly in the DS-5 debugging plattform, are there any issues known or something like a stepbystep-manual? FYI: I was at the Arrow SoC-Workshop and made my preloader with this steps: -open embedded command shell -type bsp-editor to generate the spl-bsp -type make -open ds-5 and generate a debugger -start the preloader.ds but that don't work...
