8 years agoCYCLONE V QSYS virtual memory problem
Hey all!
I am working on creating 4 lanes transceiver project on Cyclone V GX board using Qsys but it won't let me compile.. Error: Quartus Prime Analysis & Synthesis was unsuccessful. 1 error, 45 warnings Error: Peak virtual memory: 783 megabytes Error: Processing ended: Sun Oct 29 15:51:12 2017 Error: Elapsed time: 00:06:00 Error: Total CPU time (on all processors): 00:04:12 Any help would be very appreciated. Many thanks and best regards, Jaoua1 Reply
None of what you posted is the actual error.
All of this stuff:
Is mostly useless information about the compilation, spat out as part of the error log. For example the "Peak virtual memory" is not an error, it's merely stating that's what the maximum system memory used during compilation. Look back through the output messages of the compilation to find the actual error message. You can click on the Error symbol above the messages window to show only error messages.Error: Peak virtual memory: 783 megabytes Error: Processing ended: Sun Oct 29 15:51:12 2017 Error: Elapsed time: 00:06:00 Error: Total CPU time (on all processors): 00:04:12
