11 years agoCyclone V QSPI flash controller slaves
On my custom board I will have a Cyclone V and I will only be able to use 256 Kbytes non-volatile memories. Knowing that the QSPI flash controller is able to manage up to 4 different devices since it...
11 years agoThank you for your answer! Where can I find these examples? I have just found the link http://www.altera.com/support/examples/soc/soc.html where I could look at the "Quad SPI Porting" example, but are these the examples you are talking about?
I know that my memory is quite small but I want to use this memory just for the HPS side and not to program the FPGA and I believe that if I only use it for a small bare-metal application it should be enough...
