12 years ago
Cyclone V PLL Dynamic Phase Shift
did anybody successfully use basic PLL dynamic phase shift with Cyclone V? I tried to port an existing Cyclone III application, expecting that the dynamic phase shift interface would work as before, using scanclk, phase_en, updn, cntsel and phase_done PLL ports. According to documentation (AN661) it should.
But phase_done is never asserted, either before or after setting the phase_en input. I wonder if there are additional requirements not mentioned in the documentation?
Looking forward for any insights.
Frank
    --- Quote Start ---
    I think you should open a ticket on altera mysupport.
    --- Quote End ---
    Guess they'd tell me what I already know. DPS can be implemented through Megawizard, direct altera_pll component instantiation is unsupported respectively undocumented.
    The below VHDL instantiation works for me nevertheless.
    Frank
       pll1_inst : altera_pll
    	GENERIC MAP
    		pll_type => "Cyclone V",
    		pll_subtype => "DPS",
    		operation_mode => "direct",
    		m_cnt_hi_div => 15,
    		m_cnt_lo_div => 15,
    		n_cnt_hi_div => 256,
    		n_cnt_lo_div => 256,
    		c_cnt_hi_div0 => 1,
    		c_cnt_lo_div0 => 1,
    		c_cnt_hi_div1 => 1,
    		c_cnt_lo_div1 => 1,
    		c_cnt_hi_div2 => 2,
    		c_cnt_lo_div2 => 2,
    		c_cnt_hi_div3 => 2,
    		c_cnt_lo_div3 => 2,
    		c_cnt_hi_div4 => 2,
    		c_cnt_lo_div4 => 2,
    		c_cnt_hi_div5 => 2,
    		c_cnt_lo_div5 => 2,
    		n_cnt_bypass_en => "true",
    		pll_vco_div => 2,
    		pll_bwctrl => 6000,
    		pll_cp_current => 20,
    		pll_output_clk_frequency => "480.0 MHz",
    		pll_fractional_cout => 32,
    		reference_clock_frequency => "16.0 MHz",
    		number_of_clocks => N_RX,
    		output_clock_frequency0 => "240.0 MHz",
    		phase_shift0 => "0 ps",
    		duty_cycle0 => 50,
    		output_clock_frequency1 => "240.0 MHz",
    		phase_shift1 => "0 ps",
    		duty_cycle1 => 50,
    		output_clock_frequency2 => "120.0 MHz",
    		phase_shift2 => "0 ps",
    		duty_cycle2 => 50,
    		output_clock_frequency3 => "120.0 MHz",
    		phase_shift3 => "0 ps",
    		duty_cycle3 => 50,
    		output_clock_frequency4 => "120.0 MHz",
    		phase_shift4 => "0 ps",
    		duty_cycle4 => 50,
    		output_clock_frequency5 => "120.0 MHz",
    		phase_shift5 => "0 ps",
    		duty_cycle5 => 50,
    		output_clock_frequency6 => "120.0 MHz",
    		phase_shift6 => "0 ps",
    		duty_cycle6 => 50,
    		output_clock_frequency7 => "120.0 MHz",
    		phase_shift7 => "0 ps",
    		duty_cycle7 => 50
    	PORT MAP
    		rst => reset,
    		refclk => clk16,
    		scanclk => clk40,
    		phase_en => phasestep,
    		updn => phaseupdown,
    		cntsel => std_logic_vector(phase_cnt_sel),
    		outclk(N_RX-1 DOWNTO 0) => pll_out_clk,
    		phase_done => phasedone,
    		locked => pll_locked
    I found the problem. I had instantiated altera_pll directly in VHDL code as previously altpll for Cyclone III.
    But without setting a pll_subtype parameter to "DPS" and some other accompanying parameters, the dynamic phase shift ports are left unconnected without a warning. Unfortunately there's no altera_pll user manual with port and parameter documentation, only AN661 giving usage examples. Altera is apparently assuming that the new PLL IP is only implemented through Megawizard.
