12 years agoCyclone V PLL Dynamic Phase Shift
Hello, did anybody successfully use basic PLL dynamic phase shift with Cyclone V? I tried to port an existing Cyclone III application, expecting that the dynamic phase shift interface would wor...
10 years ago --- Quote Start --- I think you should open a ticket on altera mysupport. --- Quote End --- Guess they'd tell me what I already know. DPS can be implemented through Megawizard, direct altera_pll component instantiation is unsupported respectively undocumented. The below VHDL instantiation works for me nevertheless. Regards, Frank
pll1_inst : altera_pll
GENERIC MAP
pll_type => "Cyclone V",
pll_subtype => "DPS",
operation_mode => "direct",
m_cnt_hi_div => 15,
m_cnt_lo_div => 15,
n_cnt_hi_div => 256,
n_cnt_lo_div => 256,
c_cnt_hi_div0 => 1,
c_cnt_lo_div0 => 1,
c_cnt_hi_div1 => 1,
c_cnt_lo_div1 => 1,
c_cnt_hi_div2 => 2,
c_cnt_lo_div2 => 2,
c_cnt_hi_div3 => 2,
c_cnt_lo_div3 => 2,
c_cnt_hi_div4 => 2,
c_cnt_lo_div4 => 2,
c_cnt_hi_div5 => 2,
c_cnt_lo_div5 => 2,
n_cnt_bypass_en => "true",
pll_vco_div => 2,
pll_bwctrl => 6000,
pll_cp_current => 20,
pll_output_clk_frequency => "480.0 MHz",
pll_fractional_cout => 32,
reference_clock_frequency => "16.0 MHz",
number_of_clocks => N_RX,
output_clock_frequency0 => "240.0 MHz",
phase_shift0 => "0 ps",
duty_cycle0 => 50,
output_clock_frequency1 => "240.0 MHz",
phase_shift1 => "0 ps",
duty_cycle1 => 50,
output_clock_frequency2 => "120.0 MHz",
phase_shift2 => "0 ps",
duty_cycle2 => 50,
output_clock_frequency3 => "120.0 MHz",
phase_shift3 => "0 ps",
duty_cycle3 => 50,
output_clock_frequency4 => "120.0 MHz",
phase_shift4 => "0 ps",
duty_cycle4 => 50,
output_clock_frequency5 => "120.0 MHz",
phase_shift5 => "0 ps",
duty_cycle5 => 50,
output_clock_frequency6 => "120.0 MHz",
phase_shift6 => "0 ps",
duty_cycle6 => 50,
output_clock_frequency7 => "120.0 MHz",
phase_shift7 => "0 ps",
duty_cycle7 => 50
PORT MAP
rst => reset,
refclk => clk16,
scanclk => clk40,
phase_en => phasestep,
updn => phaseupdown,
cntsel => std_logic_vector(phase_cnt_sel),
outclk(N_RX-1 DOWNTO 0) => pll_out_clk,
phase_done => phasedone,
locked => pll_locked
