Cyclone V Passive Serial configuration failing after many bits.
Hello. I am attempting to configure my Cyclone V SoC FPGA using passive serial (PS) configuration on a custom PCB. Sometimes, my configuration fails at the 1st bit; other times, it fails after something like 49000 bits.
The actual error message is below - the exact number of bits varies from 1 to about 49000, so far:
Error (209010): Device did not accept configuration data (after 16384 bits sent).
Is there a best place to look for why a configuration would fail halfway through? I slowed my USB-Blaster II cable down to the slowest possible of 10 kHz.
For extra information, so far, the most common error point is 8192 bits.
- YuanLi_S_Intel
I am glad it works now. Hopefully it will help the community who have this issue. Thank You.
- YuanLi_S_Intel
The error might be caused by the following issue. Can you please check?
- Incorrect device selected
- User start up clock selected but no running clock connected to CLK_USR pin
- Communications cables not securely connected
- No power to target system
ACTION: Make sure all cables are securely connected, select a different device, check the power on the target system.Make sure you have connected a start-up clock for initialization of the CLKUSR pin, or specify that the device not use a user-supplied clock on the CLKUSR pin for initialization.
- ESaiv
Thanks for the response. I ensured each of those things were done. I fixed my issue by re-floating a few pull-up resistors on important pins such as nSTATUS, nCONFIG, etc. All works well now.
- YuanLi_S_Intel
May i know which quartus version you are using? Can you try with latest version?
- ESaiv
Hi. I am using Quartus Standard 20.1.
