ESaiv
5 years agoCyclone V Passive Serial configuration failing after many bits.
Hello. I am attempting to configure my Cyclone V SoC FPGA using passive serial (PS) configuration on a custom PCB. Sometimes, my configuration fails at the 1st bit; other times, it fails after someth...
YuanLi_S_Intel
5 years agoThe error might be caused by the following issue. Can you please check?
- Incorrect device selected
- User start up clock selected but no running clock connected to CLK_USR pin
- Communications cables not securely connected
- No power to target system
ACTION: Make sure all cables are securely connected, select a different device, check the power on the target system.Make sure you have connected a start-up clock for initialization of the CLKUSR pin, or specify that the device not use a user-supplied clock on the CLKUSR pin for initialization.
- ESaiv5 years ago
Thanks for the response. I ensured each of those things were done. I fixed my issue by re-floating a few pull-up resistors on important pins such as nSTATUS, nCONFIG, etc. All works well now.
