TPerm1
6 years agoCyclone V nCEO pin
Hi, We are using the nCEO pins in order to perform multi-device configuration. We have pulled nCEO up to VCCPGM with a 10K resistor as recommended by the document "Cyclone® V Device Family Pin Conne...
AnandRaj_S_Intel
6 years agoHi Tom,
We have to Connect the resistor to a supply that provides an acceptable input signal for the FPGA device.
VCCPGM must be high enough to meet the VIH specification of the I/O on the device and the external host.
Most important point is that the operating voltage(VCCPGM ) for the configuration input pin is independent of the I/O banks power supply, VCCIO, during configuration. Therefore, Cyclone V devices do not require configuration voltage constraints on VCCIO.
Anand
