14 years agoCyclone V LVDS & DDR3 on same bank
Hello, I am planning to use a Cyclone V 5CGTFD7D5F31 with the following requirements; - 32 bit DDR3 interface Top and Bottom (64 bit total) - 68 LVDS input p...
14 years agoHello FvM,
Thanks for the suggestion. I have made a simple project with LVDS inputs and set default I/O standard to 1.5V in the “Device and Pin Options” window. Also have 1.5V I/O in the same bank. So looks OK (even works if I use 1.2V). However what is bothering me is that it also allows me set in the Assignment Editor for the LVDS inputs: Input Termination = Differential No errors Does “Input Termination = Differential” mean that the LVDS receivers have on chip termination enabled? Thanks, Ken
