11 years agoCyclone V HS serial interface
Hi. I need an advice in high speed serial interface implementation for Cyclone V GX. I want connect my boards in next sequence: tx0 - > rx1_tx1 -> rx2_tx2 -> ...... -> rxn. Receiver_1 is connect...
11 years agoHi,
To implement XAUI, you will need 4+1 channels which will occupy one transceiver bank. To implement 4 Custom PHY, you will need another 4+1 channels which mean another transceiver bank. Thus, you would need 12 transceivers device. Not sure if the Cyclone V can use fPLL for these Custom PHY. You can double check in the documentation. If yes, probably you can fit into 9 channels device.
