11 years agoCyclone V HS serial interface
Hi. I need an advice in high speed serial interface implementation for Cyclone V GX. I want connect my boards in next sequence: tx0 - > rx1_tx1 -> rx2_tx2 -> ...... -> rxn. Receiver_1 is connect...
11 years agoThanks for your reply.
Now we are starting board design. This question becomes actual again. Main problem in this question is connection between boards like in first post. Transceivers in this configuration must work without handshaking (any interface I implement will be without link-layer). I must synchronize transmitter and receiver in manual mode. I afraid shall get problem here. Also I don't sure in independent applying receiver and transmitter (must occupy one transceiver).
