11 years agoCyclone V HS serial interface
Hi. I need an advice in high speed serial interface implementation for Cyclone V GX. I want connect my boards in next sequence: tx0 - > rx1_tx1 -> rx2_tx2 -> ...... -> rxn. Receiver_1 is connect...
11 years agoHi Andrei,
Note that the max data rate for Cyclone V GX is 3.125Gbps. Thus, if total throughput of 4 channels is 10G then there should be no issue with each one running at 2.5G. Custom PHY should be OK for this implementation.
